• 11.10.2026, 22:44
WhiteDog
Lian Li PC-P50R Armorsuit water cooling questions
Montag, 13. September 2010, 21:01
Hi Forum,
I was wondering if anyone can come with a radiator recommendation for the above case. I don't want an external system, as I like to have it neet and clean. I don't want a huge tower, so don't give me answers about buying a bigger tower.
I have made some measurements and I think there's room in the top, where the fans are, if I place the fans on the other side (inside). There should be room for a 2*120 radiator.
But do you guys have alternatives or better choices.
I would also like to hear about the different fittings. Im going for 1/4, but I'm not sure about plug'n'cool. The barb fitting look a lot more reliable. Final thing is pump and tank, what should I get there. Have in mind that it need to fit inside the case and be very effecient.
Right now im looking to watercool the CPU (i7) and the graphicscard (HD5870), I have no idea if I need a chipset cooler as well or even more.
Thanks for taking your time to read this.
/Rudi
HPF
Sonntag, 21. November 2010, 15:15
Hi!
I don't know where in the world you are located, or if you already bought a case, but there is in fact a PC-P50 case modified for watercooling. It will accommodate 1x140 or 2x140 Magicool radiator. At my request Lian Li made some minor changes to the top panel (not bezel) and included 140x140x20mm thick fans instead of the 140x140x25. Mounting is quite easy, you just move the 140 fans inside the case and put the radiator where the fans were. AFAIK now other radiator will fit. Neither will 25mm fans do as they will slightly overlap the mainboard by a few mm.
However, the case is an OEM case is only for sale in Norway. http://www.microplex.no/WebPages/Produkt…spx?plid=144582
I think Lian Li have some extra top panels and fans. If the Lian Li distributor in your country is serviceminded they may get one for you so you can replace the standard top panel.
ShOOster
PC-P50
Donnerstag, 22. März 2012, 17:23
How about this?
http://www.xtremesystems.org/forums/show…(Lian-Li-PC-P50)
Or this:
http://www.xtremesystems.org/forums/show…ht=#post4953668
I'm in the process of building the second one...waiting for the tock cycle of Ivy Bridge
chippie
Donnerstag, 22. März 2012, 18:30
@ShOOster
I would have thought they have built it by now, the thread is 18 months old :)
ShOOster
Donnerstag, 22. März 2012, 21:47
I hate you, go away
