• 30.09.2026, 14:07
gastropod
Aquasuite timer
Donnerstag, 23. September 2010, 18:09
On selecting 'timer' in Aquasuite 4.69.00 I get a continuous stream of error boxes that contain a message along the lines of "invalid argument, value 255 is not valid". Aquasuite then has to quit.
Timer functions on Aquaero seem to function ok, but software adjustment is impossible. Any ideas please.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »gastropod« (23. September 2010, 18:12)
Donnerstag, 23. September 2010, 22:06
Very likely that there is an invalid data value for the timer inside aquaeros memory. I recommend to do a reset: shut down the PC, press and hold the set button, start the PC and wait for a reset message on the display. Afterwards you can release the button. Test it again - it should work now.
gastropod
Freitag, 24. September 2010, 14:09
Many thanks Shoggy–that worked a treat! (Also, thanks for prompt reply...very much appreciated)
