• 05.10.2026, 10:20
Matt
Need some help with acquaduct 720 xt mark III
Donnerstag, 7. Oktober 2010, 19:07
Hi Shoggy! i'm here again for a small problem with mine Aquacomputer product.
When water temperature go over 28/30 degree, water start to fill out from the plexiglass top ( http://shop.aquacomputer.de/product_info…roducts_id=2471 ), exactly from the 2 holes used to remove the plexiglass cover.
And yes, i've used the rubber protection inside the package ( http://shop.aquacomputer.de/product_info…roducts_id=2003 )
any suggestion would be nice :D
stef13
Donnerstag, 7. Oktober 2010, 21:03
Dear Matt,
Probably the sealing "rubber" is not inside the "trench" .
So, this will do big leakage when the pump increase his speed.
You have to stop, open the cover and place very carfully the seal (it is not easy with big fingers :D ).
after this, place the cover and torque the screw a little at each time (not full torque or you take the risk to put out the seal again).
Check at the end that all screw are well torque.
Good luck and enjoy ,
Steff.
Freitag, 8. Oktober 2010, 09:05
Mount the cover again and tighten the outer screws at first.
