• 09.10.2026, 03:04
krypto
aquaero Revision 4 (FW) 417 needs updating
Samstag, 27. November 2010, 15:11
Hi everyone,
I been trying to update my firmware from 417 to 442 but cant find a place to download it from and now i really need an update as Fan 2 won't change speed and I'm hoping this will work, iv taken a screenshot to show whats happening also i would like to know how to flash the aquaero 4 as well.
»krypto« hat folgendes Bild angehängt:
Samstag, 27. November 2010, 22:14
You don't need to download it because it already comes with your aquasuite ;)
Click on aquaero in the menu bar and select the firmware update function.
krypto
Samstag, 27. November 2010, 22:49
Lol can't believe it was that easy i understand why i couldn't find it :wacko:
So I've flashed my aquaero 4 now and all went well but i still have a problem with "fan 2" pins, I've swapped the fans over to make sure it wasn't the fans but it's still the same and runs a full rpm and I'm not sure what i can do? any help would be much appreciated, thanks.
Sonntag, 28. November 2010, 01:07
If it runs at full speed all the time - no matter which settings - it is very likely that the voltage regulator of this channel is damaged. Normally only happens if the load is too high and the temperature gets too hot.
krypto
Sonntag, 28. November 2010, 15:28
that's what happening, I'm running 3 fans on one is that why its damaged?
Montag, 29. November 2010, 09:49
As said, very likely that it was damaged by overload/overheat.
krypto
Dienstag, 30. November 2010, 19:28
Hi, sorry for late reply just wanted to know if there was anything i can do to repair it?
Weihnachts-Shoggy
Mittwoch, 1. Dezember 2010, 09:05
That voltage regulator must be exchanged (if that is the problem).
