• 22.11.2026, 11:45
mtf
Aquaero 4 Pump 1 not avail, firmware too old!?
Montag, 21. Februar 2011, 05:31
Hi there.
I've been using my aquaero for a few years now without problems but recently i just noticed on the display as it scrolls through the screens.
Pump 1.
Not avail.
Firmware too old.
Not connectet.
That is exactly what it say's including typos.
I have run the updater, and i have the latest versions of the aquasuite (4.69.00)
Aquaero firmware (422a)
And aquaero OS (203)
Aquasuite also shows the pump as "Not connected" but the pump is running as i am getting flow
I reflashed the FW but this did not change anything.
Anyone have any ideas what's wrong?
Thanks in advance.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mtf« (21. Februar 2011, 05:32)
Montag, 21. Februar 2011, 12:22
The is normally a problem with the communication between the aquaero and the pump. Maybe you should check the connection cable to the pump.
creekin
Dienstag, 22. Februar 2011, 23:24
I have this exact same problem! :(
I have replaced my ASXT and it continues, I have also used a diff cable between ASX and AQ4.
also tried flashing, no diff.
So the fault MUST be hardware in the (brand new) AQ4.
:thumbdown:
