• 18.11.2026, 23:56
El_ninio
Question about Aquaero 5 and aquastream xt
Donnerstag, 3. März 2011, 09:10
Since the new aquaero 5 has 2 aquabus channels, high and low, will it be possible to connect two aquastream pumps in them? One in high and one in low? Or is it possible to connect them in a single aquabus channel using a Y cable that you provide and connect other aquabus devices in the spare one?
Also I read in your german topics that you have used the aquaero 5 with the waterblock at the back, how many devices have you used simutanously at the fan exits? How many Watts have you pushed it?
Thanks in advance!
Donnerstag, 3. März 2011, 14:38
Like with the aquaero 4 you only need a y-adapter to run two pumps.
The maximum that you can get out of the aquaero 5 is 60W since its channels are fully monitored in several ways to avoid any damage. Each fan channel can provide 1.65A and allows for a short overload to handle the spin up from pumps for example which draws more power.
