• 15.11.2026, 21:50
theron
aquacomputer noob asking simple questions
Samstag, 19. März 2011, 15:39
Hi guys,
Im getting myself prepared for the summer, gona sort out as good a watercooling set up as i can.
I want to buy something similar to this:
140 x3 radiator (with fans, shrouds and dampners)
120 x1 radiator (with fan, shroud and dampner)
tube shape reservoir
cpu block
gpu full cover block
northbridge block
water temperature monitor
water flow rate monitor
water level monitor
pump
fixings etc.
I have been looking at the tubemeter usb, do i need to have an aquacomputer front panel device? or can i plug it straight into the usb on my motherboard?
Are the aquacomputer temperature / flow rate monitors compatible with normal fan controllers (i have a PWM one with 2pin thermometer input)?
rig (with a view to upgrade at intels next release):
mb: DFI 790FXB M2RSH
cpu: AMD PII 940
os: WIN7 64BIT
hdds: 2X VELOCIRAPTOR RAID0, 1TB, 1.5TB, 2TB
gfx: AMD 6950
ram: 4GB DDR2 1066 C5
sound card: CREATIVE AUDIGY SE
tv tuner: HAUPPAUGE HVR1300
case: LIAN LI PC-A71F
screen: SAMSUNG 2232BW
fan controller + card reader: (not shown, made by competitors)
Dieser Beitrag wurde bereits 10 mal editiert, zuletzt von »theron« (19. März 2011, 15:54)
Samstag, 19. März 2011, 17:33
The tubemeter can be also used as a stand alone device. In this case it can be configured and monitored with the aquasuite software.
The temperature sensors might work if your controller is made for 10kOhm NTCs (very common). For the flow sensor I'm pretty sure it will not work.
theron
Samstag, 19. März 2011, 19:07
Thank yo for the very helpful answer :)
will order the water level and temperature sensors, im sure ill be back if there is a problem :D
