• 21.11.2026, 23:32
eduard
AquagrATIx HD 6990 - It do the JOB
Montag, 18. April 2011, 17:16
Hello from Spain,
Last week I have received 2 AquagrATIx for the HD 6990. After the installation, the temperature at iddle is about 30ºC less than the original fan solution, and when in full, the temp. only increases 10-15ºC. :thumbup:
And of course, 0 noise. With the 2 Hd 6990 with the original fan, when in Full load it seems that the Pc have to take off :D
Here some pictures:
By leslargi at 2011-04-18
Regards,
Eduard
Montag, 18. April 2011, 18:55
Maybe you want to use the twinconnect for both cards.
eduard
Montag, 18. April 2011, 19:28
I prefer the 2 cards independents the one of the other, for test and in case of hardware failure is more easy of unplug for separate.
cuto8
Dienstag, 19. April 2011, 20:58
Two watercooled BigBoys and still you use IDE-HDDs :thumbsup:
eduard
Donnerstag, 21. April 2011, 12:50
The IDE cable you see in the photo, is de IDE cable of the Creative X-Fi sound blaster that connect the card with front panel. All Hdd are Sata 2 and the Master is Sata 3 6Gb/s
