• 26.11.2026, 11:53
MStauning
Virtual sensor mode hickup..
Dienstag, 3. Mai 2011, 12:59
Well got it to not go wayhack on my today, and so started to play with the posiblities.
If I've create a virtual sensor (Sensor1-Sensor2), and Sensor1 shows 21,0 and Sensor2 show 20,8 then Virtual sensor1 shows 0,2.
But if Sensor1 show 21,0 and Sensor2 shows 21,2, Virtual sensor1 still shows 0,2 :wacko:
Then holding Sensor2, I've get this:
Sensor1 shows: 21,0
Sensor2 shows: 36,2
Virtual sensor shows: 15,2
The difference is -15,2 - so what is happening here?
Should I've scelect absoult mode insted, to get -15,2?
Dienstag, 3. Mai 2011, 13:37
Select the mode: Difference (Sensor1-Sensor2)
then is: Sensor1: 20, Sensor2:21 => Virtual sensor: -1
Selected mode: Difference absolute
then is: Sensor1: 20, Sensor2:21 => Virtual sensor: +1
MStauning
Dienstag, 3. Mai 2011, 13:41
My mode is differnce, just made a Virtual Sensor2 that have absoulte differnce..
They agree no matter what I've do..
So if Sensor1: 21,0
And Sensor2: 7,0
Both says: 14,0
If Sensor2: 21,0
And Sensor1: 7,0
Both says: 14,0...
None of them says -14,0
Dienstag, 3. Mai 2011, 13:47
this is correct:
Difference = Sensor 1 - Sensor 2
Sensor 1 = 21
Sensor 2 = 7
delta T = 14
but:
Sensor 1 = 7
Sensor 2 = 21
delta T = -14 ;)
MStauning
Mittwoch, 4. Mai 2011, 09:42
That is just what I've want, but dont get...
If
Sensor1 = 7
Sensor2 = 21
Then Virtual Sensor1 = 14
If
Sensor1 = 21
Sensor2 = 7
The Virtual Sensor1 = 14
This is with mode set to difference.
Virtual Sensor2, is made with mode set to Differnce absoulte. And both Virtual Sensor1 and Virtual Sensor2, allways shows the same = 14.
Something wrong here ?(
Mittwoch, 4. Mai 2011, 10:49
Is the aquaero full powered (4pin molex => 12V + 5V) or only connected via standby voltage?
Try a device reset an configure it again.
MStauning
Donnerstag, 5. Mai 2011, 07:46
Yes it has a 1Kw PSU all for it self right now, as I'm testing outside.
I'll give it a reset and go from there, thanks.
MStauning
Donnerstag, 5. Mai 2011, 12:22
A reset was all it needed, thanks. Now I've just need to make a new front, then I'm a happy camper.
