• 23.11.2026, 00:49
tnc99
Sonntag, 29. Mai 2011, 09:27
5. posted the link to Sebastian. NET 4 charged
What does this mean?
Thanks
I7 2600K
6990+6970 Watercooled EK-Plexi Crossfire
Gigabyte GA-P67A-UD7
Coolermaster Silent Pro Gold 1200W
Corsair Obsidian 800D
2 x Crusial C300 Raid 0
Corsair vangance 2x4G
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
gahlaktus
Sonntag, 29. Mai 2011, 11:14
It means download and install .Net 4 from here[url]http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=0a391abd-25c1-4fc0-919f-b21f31ab88b7[/url] .
For next time - I found this by looking through the posts from Sebastian. ;)
aioneru
Sonntag, 29. Mai 2011, 12:36
Phatboy's solution worked for me!!!
Did you install those two updates for .NET 4 ? Were they detected via standard built-in Windows Update or did you get them via MS Windows Update webiste ? What nuber exactly did they have because the second one is actually for .NET 3 and can't be installed since it's alread contained in standard Windows 7 install ?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »aioneru« (29. Mai 2011, 12:37)
tnc99
Sonntag, 29. Mai 2011, 21:31
Sebastian´s solution did not work, i still cannot run beta 1
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
gahlaktus
Sonntag, 29. Mai 2011, 21:46
I didn't check the numbers but 2 updates for .NET 4 were listed in the built-in windows update immediately after installation. I've checked my update history and they are as follows:
  • Security Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2416472)
  • Security Update for Microsoft .NET Framework 4 on Windows XP, Windows Server 2003, Windows Vista, Windows 7, Windows Server 2008, Windows Server 2008 R2 for x64-based Systems (KB2446708-) - the dash wasn't there - I've put it in as the 8 and the ) kept turning into a smiley.
On a side note - I used Revo uninstaller pro when uninstalling both .NET4 versions before reinstalling and I also used Argente (spelling?) registry cleaner (had to run it 3 times before I had a clean scan).
Hope this helps - I know how frustrating it was before I was able to fix this.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »gahlaktus« (29. Mai 2011, 21:54)
tnc99
Montag, 30. Mai 2011, 15:23
Beta 1 is working again, installed as admin, to another folder did the job :D
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
aioneru
Montag, 30. Mai 2011, 21:55
Unfortunately this method didn't work either. Installed those two updates manually and still nothing. So I uninstalled Client/Extended Framework, rebooted, installed .NET 4 again, this time it really did find those two updates (strange), installed them, rebooted, cleaned AppData, User\<Username>\AppData\Roaming and Program Files leftovers from previous Aquasuite installation, installed it to different folder and it still does the same "I will start but won't do anything" thing.
Shoggy, any updates on the tests going on your private system ?
Montag, 30. Mai 2011, 23:14
Don't ask... :D That was way too crazy. I took the system with me into the office today and the big surprise: the aquasuite was working ?(
The only idea we had it could be something with other USB devices because that was the only thing that has been changed. Back at home I was able to confirm that. My monitor has a USB interface for remote control. When it is connected I can not start the aquasuite; when unplugged everything is fine. Well, so tomorrow I also have to carry the monitor with me. Likely that this problem could also happen with other USB devices. We already have an idea so the solution is near :) Of course I can't tell if that will also solve the problems on other PCs.
Together with a customer we were also able to fix another problem which prevents the aquasuite to run. Besides that a few other things have been fixed.
So far it looks good that we will have a Beta 3 available tomorrow.
Phatboy69
Dienstag, 31. Mai 2011, 02:37
Yeah I mentioned the USB device conflict somewhere before, I think over at xtremesystems.org, mabye even earlier in this thread I cant remember.
I plugged my Iphone in the other day and Aquasuite crashed. It crashed a subsequent 2-3 times and then 3rd time started ok.
A USB conflict sounds like the most likely scenario. I dont know a lot about USB but I believe different devices have polling intervals and maybe a high frequency polling interval from another device disrupts USB polling in Aquasuite causing a crash.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Dienstag, 31. Mai 2011, 08:57
Our programmer is already working on it. We also have an iPhone here for tests.
tnc99
Dienstag, 31. Mai 2011, 10:31
I have nothing else than a G15 G3 keyboard mouse connected, did have a crash when connecting a sidewinder joystick, i dont think the startup problem with beta 2 is an usb issue.
Hope you find a solution.
Thanks
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
Dienstag, 31. Mai 2011, 11:34
Well, IT IS - we were able to reproduce it and we are also pretty sure the problem is caused by several USB devices. The handling of the aquasuite for USB devices had a problem which surely effects many of you. It is fixed now :)
tnc99
Dienstag, 31. Mai 2011, 12:11
That sounds great!
Hope Beta 3 will be available today :P
To mention, i also of curce have aquastream xt and aquearo 5 on usb :rolleyes:
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
Dienstag, 31. Mai 2011, 14:22
aquasuite 2012 beta 3 is online
http://aquacomputer.de/software.html
tnc99
Dienstag, 31. Mai 2011, 15:14
:thumbsup:
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
Dienstag, 31. Mai 2011, 15:40
@tnc99
it works now?
tnc99
Dienstag, 31. Mai 2011, 15:43
I need to get home from work first, will reply asap.
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
tnc99
Dienstag, 31. Mai 2011, 16:46
It is working! :thumbup:
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
aioneru
Dienstag, 31. Mai 2011, 21:16
I confirm this. It's running without any problems every time.
Paradoxxx
Mittwoch, 1. Juni 2011, 00:08
Running fine here as well, I don't know if its just me but it seems faster...
Is there a change log?
