• 15.11.2026, 21:32
Phatboy69
A5 Firmware request 48W PA2 startup current
Mittwoch, 1. Juni 2011, 13:19
Hi Guys can you please put the 48W startup limit for the PA2s in the next A5 firmware? My PA2 connected fans are running right on the 2A limit at startup and tripping an overcurrent shutdown sometimes.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Donnerstag, 2. Juni 2011, 01:34
Do you have Firmware 1011 on your aquaero because a bug with the overload detection has been fixed there.
Phatboy69
Donnerstag, 2. Juni 2011, 02:04
Hi Shoggy I can confirm Im running 1011. The unit is fine running up to 2amps, where as before it would only support 1.5A. What Im asking for is for the firmware to allow the 48W startboost limit of the PA2 which is 4A for about 30secs so that the startup current doesnt trip an overload.
I thought the PA2 had a 48W startboost limit for handling high current pump start etc?
Can you please confirm
A)PA2 supports 48w Startboost?
B)Its possible to patch the A5 firmware to take advantage of this?
Cheers
Donnerstag, 2. Juni 2011, 02:58
A) yes, of course it does.
B) will have to ask our programmer so I can't answer this at the moment.
