• 21.11.2026, 09:14
robned
Aquaero 5 XT and Tubemeter fails...
Donnerstag, 2. Juni 2011, 04:06
I have set the Tubemeter so it triggers a warning and an alarm if water goes under a certain leve. However, I have a problem with tubemeter loosing contact with Aquaero 5 XT during a second or two. This happens every 15-20 minutes and the alarm goes off.
The whole purpose with the alarm is to shut off the computer in case of sudden drop of liquid level. However, it doesnt work when I get false positive alarms shutting of the PC.
I have noticed that you have fixed the flow issue when Aquastream XT was "resetting" and was causing this problem. I was hoping you could put some kind of time delay for failure of tubemeter so that it doesn't have to give off an alarm immediately. Can you dont try to fix this for tubemeter as well?
Regards
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »robned« (2. Juni 2011, 09:31)
BazManDude
Montag, 6. Juni 2011, 11:06
I have the exact same issue. Hopefully this will be resolved in the next firmware update
