• 29.11.2026, 03:29
robned
Does Aquaero 5 XT work with Aquaxtream Ultra?
Sonntag, 12. Juni 2011, 11:41
I have the Aquastream Ultra.
Whenever I used Aquasuite 4.72 with Aquaero 5 XT I could set the pump frequency and set silent / manual / auto mode.
With Aquasuite 2012 Beta 3 and Aquastram Ultra connected to Aquaero 5 XT through the 3 pin connector to high speed aquabus, I can't get any screen in Aquasuite 2012 to show pump.
I have connectected the USB as well without success.
Can anyone confirm that Aquastream Ultra is supposed to work with Aquero 5 XT and Aquuasuite 2012?
With Aquasuite 4.72 it only works with USB connected...
Please help.
Phatboy69
Sonntag, 12. Juni 2011, 12:07
It is supposed to work with AE5 but its not enabled in 2012 yet.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Freitag, 17. Juni 2011, 09:55
The aquastream XT has not been integrated to aquasuite 2012 yet. So far you can control it only directly through the device or you use the old aquasuite 4.72.
