• 12.10.2026, 14:50
sparkeyrr
aquaro on G19
Dienstag, 21. Juni 2011, 12:16
All good mateKeep me posted if you achieve any headway with LCD HYP.Noticed you do flight Sims I have a array of 3 monitors with a pro track head tracker way cool toy :thumbsup:
Phatboy69
RE: aquaro on G19
Dienstag, 21. Juni 2011, 13:23
Well I managed to look into the sqlite database and all the structures are there but there's no data being stored in it except for static data for setting and configuration at the moment.
The good news is when they enable the desktop functions and export functions all the data we can see on the overview page should be accessible, either in a database file or possibly in XML.
When they do this it will be possible to write your hype scripts to import the data. It will be complex for non-programmers or basic pc users but with a bit of determination and work it will be possible.
If we are really lucky we might be able to find an experienced scripter or programmer to do all the work.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Phatboy69« (21. Juni 2011, 13:28)
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Phatboy69
Freitag, 24. Juni 2011, 11:40
Another new find from the german threads...
If you want startboost to work on the PA2s connected to the AE5 you have to first disable startboost on the PA2s by connecting via USB to each PA2 individually and turn startboost off in Aquasuite 4.72.
I managed to stop my fans from peaking at 2.1A and tripping an overload as they sometimes would during startup. I set a 60% startboost in aquasuite 2012 after disabling in PA2s to get it to work!
Phatboy69
Dienstag, 11. Oktober 2011, 13:44
Here's some updated pics of the Aquaero 5 XT and 6 PowerAdjust2 Ultras all sleeved.
Im redoing my whole system with a pretty major upgrade and full sleeving and cable management.. more pics in a new thread soon when all my AC blocks arrive... soon hopefully! ;)
Not the neatest job but damn it was fiddly!
Black Face Plate is on its way to me too finally.
Mittwoch, 12. Oktober 2011, 11:03
OH MY GOD :D
Namron
Mittwoch, 12. Oktober 2011, 11:57
AWESOME!!!...... :thumbup: ..... Fantastic work yet again PB, Stunning set-up :D
N.
Phatboy69
Donnerstag, 20. Oktober 2011, 15:12
No words needed! ;)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Phatboy69« (20. Oktober 2011, 15:13)
Phatboy69
Donnerstag, 20. Oktober 2011, 15:14
Part 1 installed
Phatboy69
Donnerstag, 20. Oktober 2011, 15:15
New Toy for some cutting this week... :)
Dremel 4000 4/50 with an extra 65 piece cutting kit.
Phatboy69
Donnerstag, 20. Oktober 2011, 15:16
Here's the GPU's done!
Phatboy69
Donnerstag, 20. Oktober 2011, 15:20
Here's a couple pics of me testing the Aquaero wiring before I fitted all the blocks...
Phatboy69
Freitag, 21. Oktober 2011, 13:10
Tubing all done!!! What do you think??
Phatboy69
Freitag, 21. Oktober 2011, 14:24
Here's my first video with the new iPhone 4S.
http://youtu.be/KxTYLUUa35w?hd=1
Phatboy69
Samstag, 22. Oktober 2011, 11:22
IT LIVES!!!!! :shock::shock::shock:
Still have some tidying to do..
The bays are not screwed in yet because I still need to work around them for the final cabling and tidying and to able to check for leaks! :):):)
Idle Temperatures
:thumbup::thumbup:
Phatboy69
Montag, 31. Oktober 2011, 15:01
IL2 COD 6030x1080 Nvidia 2D Surround - Hurri's vs BF110's
4way SLI GPUs all maxed at 99% avg 30FPS - This game still needs heaps of optimisation and the developers have promised a minimum 50% performance improvement with the next patch. I used to get 60FPS with eyefinity quad 5870s with an earlier beta that used xfire/sli properly.
http://www.youtube.com/watch?v=JbJfvrd553U
The beast that powers IL2 COD
http://www.youtube.com/watch?v=-mHCNW1lkk4
frank anderson
Mittwoch, 9. November 2011, 15:21
Hi Phatboy, beautiful setup as usual..
Just wanted to ask how you got your fans setup on the PA2's? using a 3 way splitter? I am trying to make some myself, it's a real pain in the rear..
Phatboy69
Sonntag, 13. November 2011, 07:15
I made my own fan cables with custom lengths, soldered and put new crimps and fan connectors on them.
markjason
Mittwoch, 16. November 2011, 17:47
Just by looking at the size of the waterblock one can tell that the video card is going to be huge. That's one monster of a waterblock!
___________________
presentation folders
custom folders
