• 29.11.2026, 15:34
dopax007
Doubts about the compatibility of the Aquagrafx for GTX570
Freitag, 8. Juli 2011, 22:36
Greetings :
I would like to know if any of the two products Aquagrafx for GTX570 is compatible with my GPU MSI GEFORCE GTX 570 TWIN FROZR II/OC 1280Mb DDR5 750Mhz .
Thank you in advance
Montag, 11. Juli 2011, 11:55
The Frozr II/OC should use the regular reference layout so you can use the GTX580/570 block in copper or nickel plated.
dopax007
Montag, 11. Juli 2011, 17:16
Greetings , Shoggy ;
According to the cooling configurator of EK, also gave it as a PCB of reference but i wanted to confirm, and you've already done . Thank You
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dopax007« (13. Juli 2011, 18:26)
