• 07.10.2026, 14:13
imteck
Aquaaero 5 Fan Speed control based on RPM?
Dienstag, 19. Juli 2011, 00:43
HI,
I am planning on buying the Aquaaero 5 XT and I was wondering if the controller can control the fan speed based on the tach feedback? I can't find the user manual, so I am posting this question here.
Thanks
Phatboy69
Dienstag, 19. Juli 2011, 10:54
Yes it can, either voltage or RPM.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Silvermaul
Mittwoch, 27. Juli 2011, 22:18
How do I control the fan speed? I can see the fan in the suite and I change the settings but nothing happens?!
Silvermaul
Mittwoch, 27. Juli 2011, 22:25
Forget it, I just hooked it up to the mobo after seeing this :
http://imageshack.us/photo/my-images/823/lolcao.png/
Serious fail...
