• 08.10.2026, 11:55
MStauning
Can AE5 control light on/off?
Dienstag, 23. August 2011, 09:50
Was thinking that the PWM1 and PWM2 outputs, could be used to power a coldcatode - or not?
Dienstag, 23. August 2011, 15:03
No, that is not possible since these ports do not provide enough power to drive a cold cathode.
Silvermaul
Dienstag, 23. August 2011, 18:20
You could however create a rudimentary relay circuit which could control a switch and does your job :) There are tones of such circuits floating around in the web. Just google it :)
Actually I am interested in this myself since I run out of pci expansion slots on the back of my case so I would like to control this programatically.
MStauning
Samstag, 3. September 2011, 15:19
How many watts can we draw from those ports?
And a relay is on the way, to test with..
Thanks.
Samstag, 3. September 2011, 15:27
Which ports exactly?
The normal fan headers 1 to 4 can provide up to 1.65 A at 12 V which comes to almost 20 W while the PWM ports can provide up to 1 A, they are always running with 12 V.
MStauning
Mittwoch, 7. September 2011, 03:45
Well havent got it by my side right now, but I'm sure they are called 12V PWM, they are right next to the fan headers 1-4.
