Du bist nicht angemeldet.
aphasia
Donnerstag, 15. September 2011, 04:47
aphasia
aphasia
no problem, glad my 'experience' was able to help someone out.Hey aphasia,
thank you for your solution with the 3rd pcie slot.
Now my pc boot with ae5 connected.
aphasia
aphasia
hi shoggy, sent email a couple of days ago, just waiting on reply.Please write to info @ aqua-computer.de for further details.
any thoughts on this. may be its tied to the touch sensitive key issue?
aphasia
Tech20635
just purchased my aquaero 5 xt and having issues setting up the software suite
anyway trying to hook-up the 'Aquaero 5' fan controller to my Asus CHV via the USB connector (to access unit via software suite in windows). not having much success.
every time i connect the USB cable to MB, the boot process halts after BIOS loads (black screen, blinking underscore).
i'm positive i've got the pin-out on cable connected to the correct pin headers
here's a pic of the USB connector cable that came with the unit.
going from left to right -> black= GND/ black= GND/ green= D+/ white= D-/ red= +5v
the rear of the unit (USB connector circled in red). the header is colour keyed so no issues messing that up. red +5v on right, black GND on left.
USB connector pin-out from Asus CHV manual. obviously the connector cable is a 'half-plug). should have just been a case of matching up the +5v & GND pins. i've tried connecting the cable up to both the top & bottom rows of the plug on each header (USB910 & USB1112)
the MB boots fine without cable connected but fails with it connected.
my only other thought was messing with the SouthBridge USB options in BIOS (enable/disable legacy USB).
unless i'm missing something, i can't for the life of me get this to work.
any suggestions?
Hey bud I finally figured out how to successfully connect the aquaero 5 to MB. You have to set the BIOS USB to the following
In the BIOS, the USB legacy support was activated
USB setting in BIOS
Under ADVANCED \ USB CONFIGURATION \ SB CONFIGURATION:
OHCI HC (Bus 0 Dev 18 FN0): Enabled
OHCI HC (Bus 0 Dev 19 FN0): Enabled
OHCI HC (Bus 0 Dev 22 FN0): Enabled
OHCI HC (Bus 0 Dev 20 FN5): Enabled
Otherwise, under ADVANCED \ USB CONFIGURATION:
Antiquated USB Support: Enabled
USB 3.0 Support: Enabled
EHCI hand-off: Disabled
Now I've felt for 1000x, startup and adjustment, the
Antiquated USB Support: Disabled meaning disable the top one cant have both enabled it conflicts on the MB and aquaero 5.
Now everything works, everything is running normally highly Below, optimally
Borgstif
I have the aquaero 5 PRO and the Asus Crosshair V and I have the same USB problem. But only after a firmware update. Worked fine out of the box!!. The only way i can get my PC to start up is if i turn off legacy USB support in my bios.Very strange problem there with the mainboard. It should have nothing to do with the installed firmware on the device since the USB routines have not been changed at all from the initial release to the latest update.
