• 21.11.2026, 00:26
ledon
Fan does not work on 4 Aquaero 5 Pro
Freitag, 23. September 2011, 22:34
Hello,
I use a Aquaero Pro 5 with 2 Flow sensor, one on Flow and the other on a Fan 1.
My fans are on Fan 2, 3 and 4.
The problem is that Fan 4 does not work except: PWM Crotrolled.
Fan 4 works if I disable FlowSensor 2 of Fan 1.
Another problem 2 Aquaero 5 are not compatible with AquaSuite 2012 v8 x64, impossible to manage the information of two Aquaero with the software, only one works properly.
Strongly that the software is stable, until I began my 2 Aquaero 4.
Sorry for my english ;)
Donnerstag, 29. September 2011, 09:58
Likely that both problems are a bug in the firmware and software. I have forwarded it to our programmer. He will have a look into it and will fix it if it is a bug.
Donnerstag, 29. September 2011, 11:02
we have testet it.
No problems.
Try: connect only one aquaero 5 with usb
reflash firmware 1016 and test it again.
