• 07.10.2026, 16:33
LeetDonkey
Poweradjust 2 and aquaero 5 xt
Freitag, 14. Oktober 2011, 10:46
Hello
I'm currently looking to purchase an Aquaero 5 XT and a couple of poweradjust 2.
Is it correctly understood that you just connect the Poweradjust 2's to the Aquaero via the Aquabus and then you can simply control it all from the same control panel?
My plan is to control 7 fans and 2 Laing D5's via the Aquaero.
I will monitor pump RPM as well.
My plan is to attach a inline temperature sensor to the Aquaero and then control fan and pump speed based on the water temperature.
Could someone tell me if I need anything else than 2 x poweradjust 2 and 1 x aquaero 5 xt?
I'm quite new at adding a controller to my water loop and would like to make sure I get everything right before ordering.
Thanks
Freitag, 14. Oktober 2011, 17:06
You are right. When you connect the poweradjust to the aquaero they can be used like a 5th and 6th fan channel.
You will not need anything else. The necessary connection cables are already included with the poweradjust controllers.
