• 29.11.2026, 21:26
kleox64
Damaged Aquaero 4 - Stays at main screen
Dienstag, 15. November 2011, 09:05
My aquaero I think has been damaged by a faulty USB header on my motherboard, I've tried to revive it on another PC without luck.
Disconnected everything, the damn thing keeps rebooting and/or most of the time stays at the main screen.
Is there any way to force a flash of the firmware as the aqua suite says the version of the OS is 0 for the unit.
Ive also done the EEPROM reset without any luck.
The unit is very old probably 2004/2005 when ever the v4 was first released.
Dienstag, 15. November 2011, 15:39
There is no way to force an OS update. You could try to play around with the old OS updater tool but I guess it will not let you flash the device again.
We can reprogram the CPU directly but in this case we would need the device here in our company and I guess with all the shipping costs it is not really worth it - especially if you keep in mind that maybe the device itself is faulty and can not be repaired.
