• 09.07.2026, 15:43
ad120
Can Aquaero 5 XT control a Alphacool vpp655 pump?
Mittwoch, 30. November 2011, 02:02
  1. It uses a 4 pin molex, but if I converted that to a standard 3 pin fan header, can I plug it into the aquaero to control?
  2. Will the aquaero provide enough power to be able to run? Or will I have to buy a power adjust or other type of board?
  3. And what are the PWM 1/2 ports used for?
Standard voltage: 12V DC
Power: 23W
Allowable Voltage: 8-24V DC
Current connection: 4 Pin Molex
http://www.frozencpu.com/products/13147/…le_Edition.html
Thanks :D
Phatboy69
Mittwoch, 30. November 2011, 09:08
Yes, I've done that to all 4 of my 655 pumps which are all rebadged D5 pumps.
PWM 1/2 are for controlling things like led lights and other low current devices it not a PWM controller like channel 4 is, its just a PWM power source which is a digital power source instead of analogue to make it more efficient. Max load of 1A@12V each.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Phatboy69« (30. November 2011, 09:21)
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
ad120
Mittwoch, 30. November 2011, 09:42
thanks for the info. It is really helpful.
Do you plug the pump directly to the aquaero? or do you use one of the auxiliary boards?
Phatboy69
Mittwoch, 30. November 2011, 09:52
I have 2 on the A5 and 2 on 2 PA2s. (1 per PA2)
