• 11.10.2026, 18:17
rich.switzer
2 Aquaero 5's, dual power supplies and ATX Break
Montag, 5. Dezember 2011, 21:46
I have a system that is split up between a Corsair 800D and a Mountain Mods Pedestal. Each case has an ATX power supply and it's own Aquareo 5. I'm trying to accomplish the following.
1. If the Relais on either Aquaero is tripped due to an alarm, both PS shut down via ATX Break. I know how to setup the alarms but I am not 100% on the wiring.
2. Both Power Supplies are turned on/off when power switch is activated on Case #1.
Please see the following for how I think I should setup the wiring. Am I on the right track?
rich.switzer
It's Alive!!!
Montag, 6. Februar 2012, 17:40
Here is an updated map on how I got this working....
The following allows both 1 & 2 and I can confirm it's working perfect :thumbsup:
1. If the Relay on either Aquaero is tripped due to an alarm, both Power Supplies
