• 14.11.2026, 05:42
edman911
Poweradjust 2 Ultra LED blinking
Montag, 9. Januar 2012, 00:45
Just finished hooking up my Aquaero 5 XT + 3 x poweradjust 2.
Everything seems to be working in order but one of the poweradjust LED's are blinking. This is the one connected to my D5/mcp655 using the enclosed molex to 3pin adapter. Everything has been flash properly and connected(I think) the right way. Why does this one have a blinking LED?
Phatboy69
Mittwoch, 11. Januar 2012, 08:40
Check the alarms on the A5XT from the front panel, you will probably find it had an overload of some sort.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
