• 23.11.2026, 01:23
OC2000
Tubemeter Driver?
Mittwoch, 11. Januar 2012, 05:24
I have hooked my Tubemeter to the PC via the PC USB cable, and continually receiving a message saying the device failed to install. Device settings show the device as an "unknown device"
Further more when connected I see no LED turning on via the tubemeter.
Is there a driver I can use to install this as Aquasuite 4.72 does not pick the tubemeter up either.
Thanks
bcikota
Mittwoch, 11. Januar 2012, 19:17
Hi OC2000,
There is no driver for the Tubemeter. It is a standard USB HID device, so Windows already has all that it needs for it.
Did you connect it correctly? It is easy to make a mistake orientating the USB connector. If I remember correctly, Pin 1 of the Tubemeter should have the black wire connected and Pin 5 the red one. Pin 1 is marked. Check your Tubemeter manual to make sure.
Kind regards,
Boris Cikota.
OC2000
Dienstag, 17. Januar 2012, 07:56
Connection wise must be correct. The fact that it recognizes there is a USB device, but fails to install it, suggests I got a faulty Tube meter.
How do I go about getting a replacement as they're not cheap!
Thanks
bcikota
Dienstag, 17. Januar 2012, 11:56
Hi OC2000,
For the replacement you probably have to contact Aqua computer if you bought it directly from them. There is a RMA form here: http://www.aquacomputer.de/rma-formular.html
Did you try deleting the unrecognized device and letting Windows detect the tubemeter again? Sometimes it helps.
Kind regards,
Boris.
OC2000
Dienstag, 17. Januar 2012, 13:10
Yep did that many times, also updated my drivers. Pity I don't have another computer to test it on, but the aquaero 5 and 3 PAs were all detected.
