• 29.11.2026, 08:53
AP2
aquero 5 XT - do i need a poweradjust?
Mittwoch, 18. Januar 2012, 06:17
So, im building a quiet hackintosh file server (2U) and decided to watercool my setup. these are the items that i have purchased thus far - 240 copper modularity rad/d5 pump/res combo, copper kryos HF cpu block, 3 copper micro harddrive blocks, and aquaero 5 xt. i plan on controlling the 2 fans on the radiator and 2 chassis fans. so with that said... do i need a poweradjust? if so, what are the differences between poweradjust and poweradjust 2?
thanks!
bcikota
Mittwoch, 18. Januar 2012, 11:27
Hi AP2,
If I understood you correctly, you plan on connecting 4 fans to your Aquaero? If so, and if those fans are not some server cooling monsters (38 mm Deltas or similar), you should have no problems connecting them to Aquaero. I have 6 120 mm Yate Loons and 3 140 mm Noiseblockers on my Aquaero and the temperatures are reasonable.
I am not sure you can even buy Poweradjust any more, I only see Poweradjust 2 in the Aqua computer shop, but if you're not planning to connect anything else you don't need one.
Kind regards,
Boris.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »bcikota« (18. Januar 2012, 15:15)
Rioga
Mittwoch, 18. Januar 2012, 13:04
If you plan to connect d the D5 to the aquaero, you will need the powerAdjust2.
Regards
frank anderson
Mittwoch, 18. Januar 2012, 18:10
hello there..
It has been done, 2x D5 and 6 fans on the aquaero w/ waterblock..
search post by phatboy69, he did it on his setup..
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »frank anderson« (18. Januar 2012, 18:12)
Thorvald
Donnerstag, 19. Januar 2012, 02:00
Personally I don't see the point of buying the PowerAdjust 2. The price of a PA2 with the mounting bracket is the same price as an Aquaero LT (without the mounting brackets however).
Then you have a ton of more fan and expansion options for the same cost of the PA2 & Bracket (Way more fans, sensors, etc).
When I expand, I plan to just add LT's instead of PA2's unless someone can provide a good reason why... Might be something I've missed since I can't read German.
Cheers
Tim
bcikota
Donnerstag, 19. Januar 2012, 09:47
I think I read somewhere that you can only have two Aquaeros in the system at the same time. But that still gives you more channels/sensors then buying one Poweradjust 2.
Also, I remember reading something about an future update to the Aquaero firmware which would allow one of them to work as a slave device to the other.
One nice thing about a Poweradjust 2 is that you don't have to mount it in the free 5.25" space, you can put it anywhere in the case. It supports higher loads and you can daisy chain 6 of them I think.
Kind regards,
Boris.
AP2
Donnerstag, 19. Januar 2012, 11:28
thanks for all the replies!
i do plan on connecting the D5 to the aquaero, so it looks like i will need a poweradjust 2 correct? so in total i will have 2 noctua 120 fans for the rad, 2 80 noctua fans for chassis, d5 pump, and also a flow meter.
slightly off topic, but what is the best type of fluid and tube size for my setup?
thanks again!
bcikota
Donnerstag, 19. Januar 2012, 11:57
Hm, I would agree with frank anderson that you could run those 4 fans and the pump with the Aquaero only, even maybe with the big passive cooler, if not that, with the water block for sure.
Check the measurements done here: http://martinsliquidlab.org/2011/12/20/a…ew-guide-wip/9/
And a fully loaded user installation: Fully Loaded Aquaero 5 XT Installation!
Kind regards,
Boris.
Nihil Simile
Donnerstag, 19. Januar 2012, 17:47
If you can afford it I would go for the Poweradjust 2. Its my opinion that its better not to have such a load on the Aquaero, even though it can handle it. Its like driving your car fast all the time it will shorten the life span of it. I would go with the 3/8 (10 mm) hose I know that most will not agree but if you look at your water block the opening is only 3/8 at least on the Cuplex Kryos HF, I have also seen other forums that say 1/2 (13mm) does not have that much of a gain in performance. This make sense because the inline temperature sensors, & blocks usually reduce down to 3/8 any way.
