• 11.10.2026, 17:01
Eggy88
Couple of questions regarding Laing D5 and AC "High Flow" flow meter.
Freitag, 20. Januar 2012, 14:14
- I have two Laing D5's both without RPM sensors, each one is connected to a PA2. Is it and possible to controll the speed of them and get a RPM reading? I heard that you could make a "false" tach signal for the purpose of controlling the pumps if they don't have one themselves, how do i do this?
- Im getting low numbers (~150l/h) with 2x Laing D5 @ full speed, they are connected in series. I have the following parts in my loop.
- 2x 360mm Rads
- 1x 120mm Rad.
- 1x EK Supreeme LTX cpu block.
- 3x Coolance VID-AR697 (6970 full block)
- 1x AC "High flow" flow meter.
- 2x Laing D5 In a Coolance 452x2 res.
- 2x Coolance QDC.
- Total of 15x 90degree bends.
I would asume that i would get more then the 150l/h im seeing now?
Nihil Simile
Freitag, 20. Januar 2012, 17:58
http://martinsliquidlab.org/2011/03/09/laing-ddc-1-ddc-1t/ Take a look at this Didn't see how to mod RPM signal
bcikota
Freitag, 20. Januar 2012, 19:20
Hi Eggy88,
Did you set the proper calibration value for the flow sensor in Aquaero? The default one is too high. That would give you lower flow readings.
The calibration value for the high flow sensor is 169. It can be set from Aquasuite or directly from Aquaero.
Kind regards,
Boris.
Eggy88
Freitag, 20. Januar 2012, 23:17
I have seen this and first of all its the Laing DDC not the D5, secondly he only thinks its RPM, but no tests done. I dont want to drain the whole loop and take the pumps apart so a false RPM signal is perfect, i just want to be able to controll the speed of the pumps
Hi Eggy88,
Kind regards,
Boris.
Yes i have changed it to 169. With the default 256 i got ~100l/h.
Is not the 150 l/h abit low for my loop? The loop is not 100% finish bleeding so could get some more but 150l/h is way less then what i tought i would get with dual D5's.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Eggy88« (20. Januar 2012, 23:21)
OC2000
Samstag, 21. Januar 2012, 04:54
That's funny as my Ac high flow also reads 150 lh, which I'm worried about being too low also. Only using one D5 though
Eggy88
Samstag, 21. Januar 2012, 08:46
What does your loop look like?
OC2000
Samstag, 21. Januar 2012, 09:30
http://forums.vr-zone.com/uvnium/1010363…ts-here-15.html
You can see pics at the bottom. I use OC2010 as my username. Any suggestions would be appreciated. Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »OC2000« (21. Januar 2012, 09:32)
Eggy88
Samstag, 21. Januar 2012, 20:00
I would asume thats OK? 150l/h = 0.7Gpm. You have 3 rads, + dual gpu + cpu and the small block on the A5. That combined with all the bends etc looks ok. I get the same with dual pump. And i only have 1 gpu more, but the cards are running in parallel so should be litle to no restriction.
