• 29.09.2026, 23:02
X79
Nihil Simile
X79
Freitag, 20. Januar 2012, 20:19
Any one using Socket 2011 X79 platform, and Aqua suite 2011? If so what if any problems have you been encountering? Kind regards.
matthelm
Freitag, 27. Juli 2012, 01:02
I'm using the brand new 2012 beta 15 with a Gigabyte X79, and all is fine so far.
chippie
RE: X79
Freitag, 27. Juli 2012, 01:39
What sort of issues would you expect? This is a broad question as you are talking about running software on a platform that has hundreds of combinations! In reality most issues would be with the OS rather than the hardware as apart from the USB connection (the header will vary depending on the mb manufacturer) the software does not have any integration with the motherboard (ok, except for software sensor but that is a AIDA64 issue).
As the Aqua Computer line of products are pretty much high end enthusiast I would also think that the majority of people would be running on x79 boards.
But in answer to your question, I also have no issues on running the software on several x79 builds!
