• 22.11.2026, 23:06
Thorvald
Bug Report - Aquasuite 2012 Beta 10 to 12 - Will not properly remember screen position when restarting
Samstag, 21. Januar 2012, 16:00
Been meaing to report this one for a while, I run four monitors with extended desktop and Aquasuite is on one of them.
When I shut it down and restart (or re-run Aquasuite), it does not start up in the same position, it is slightly shifted and the window is slightly smaller.
Looks like the logic behind screen geometry needs some tweaking.
bcikota
Sonntag, 22. Januar 2012, 22:07
Hi Thorvald,
This is probably a multi-monitor issue, I did not notice the problem on my single monitor setup.
Aquasuite seems to save its position in "C:\ProgramData\aquasuite 2012\aquasuite.xml" if you are running Windows 7, so maybe you can have a look there and try to figure out what is going on.
Kind regards,
Boris.
