• 30.11.2026, 23:28
JB3
Poweradjust 2 Ultras Not Seen In Aquasuite 2012 Beta
Mittwoch, 8. Februar 2012, 05:07
I have 6 Poweradjust 2 Ultras linked together via Aquabus and connected to my Aquero 5 XT via Aquabus. The Aquero 5XT is connected to my mother board via USB. I can not see any of the Poweradjust 2 Ultras in Aquasuite 2012 Beta. What do I need to do to see them and adjust fan speeds in Aquasuite 2012 Beta?
bcikota
Mittwoch, 8. Februar 2012, 08:42
Hi JB3,
First, you should setup your Poweradjusts using the older Aquasuite version 4.72, which you can get here . You need to connect each Poweradjust over USB and adjust its Aquabus address.
Once this is done, you can disconnect the USB, plug them in over Aquabus and you should see extra fan channels in your Aquasuite 2012. So, basically, instead of 4 fan channels you should have 10 channels. Each Poweradjust is shown as an extra channel.
Kind regards,
Boris.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »bcikota« (8. Februar 2012, 08:45)
