• 18.11.2026, 11:01
Nihil Simile
Information needed
Sonntag, 26. Februar 2012, 23:48
I have some questions about flashing the new firmware. 1 I have seen that sometimes the firmware won't take without a full reset. This is done by jumping # 5 & # 8 pins please clarify this step, is it a bridge of one pin to another on the same sensor # , or is it a bridge from pin # 5 to pin # 8 ? please help.
Jays_sho
Donnerstag, 15. März 2012, 01:51
Yes can someone clarify this please!
Jays_sho
Donnerstag, 15. März 2012, 02:03
never mind
1.) Turn off the PC and remove the standby power if you are using it.
2.) Remove all sensors from the aquaero.
3.) Place four jumpers on the temperature sensor connectors 5 to 8.
4.) Power on the system and after a few seconds you should see a recovery mode screen in the aquaero display.
6.) Turn the PC off and remove the jumpers from the aquaero.
7.) Start the PC and use the latest aquasuite 2012 software to flash the firmware onto the aquaero. It should perform a restart afterwards so you should see the regular screens now.
8.) Turn off the PC, connect all sensors etc. again and start the PC.
