• 02.10.2026, 10:36
Rjrolyn
Aquaero 5XT Power Down
Dienstag, 6. März 2012, 01:17
Greetings everyone .........
I just installed / finished the upgrade from my Aquaero 4 Got everything hooked up for the Aquaero 5Xt along with the 1-PA2. My question is when I turn off the PC my Aquaero 5xt stays on or stand by mode or hibernation mode. The 3 red lights are off. Is this normail ? if theres a workaround this pls schime in. Thanks in advance
»Rjrolyn« hat folgendes Bild angehängt:
Nihil Simile
Dienstag, 6. März 2012, 02:30
Have you checked the setting? You can adjust light output in the on mode and stand by mode.
Rjrolyn
Dienstag, 6. März 2012, 02:40
I have not tried it yet .. So in other words this is normal
bcikota
Dienstag, 6. März 2012, 08:45
Yup, if you did not set it up differently, by default Aquaero will be showing you the same screens like it does when it is powered.
You can adjust backlight, contrast and brightness in Standby mode from Aquasuite, or you can make a separate profile for Power off/Standby mode.
Kind regards,
Boris.
