• 22.11.2026, 09:53
drbo
Any plans for Waterblock to PA2?
Mittwoch, 7. März 2012, 15:27
I am currently running 3x PA2 in my rig, mounted in a frame ("einbaublende ").
But these are getting relatively hot.
So ,my question is, is there any plan of making a waterblock for these?
I would suggest 1 waterblock that covers 3x PA2 mounted in a frame, preferably made of cupper/delrin.
With hope of watercooling my PA2s soon.
drbo 8)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »drbo« (7. März 2012, 15:28)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
bcikota
Mittwoch, 7. März 2012, 15:37
I was thinking about the same thing! I am using my PA2 to power the pump and the temperature goes up quite quickly once the voltage comes down.
I don't think they'll make a block for it, from what I've seen people are using them in many different configurations, and probably not many people have three mounted in the holder.
I have copied a solution from one of the users on this forum and I am cooling down the PA's by using an old Corsair memory cooler. PA heat-sinks don't actually require a lot of airflow, I am running the cooler at very low RPM's, virtually noiseless, and it takes 15C of the VRM temperature easy.
Kind regards,
Boris.
