• 04.10.2026, 06:06
hugostiglitz
Aquaero 5 Pro + INS-FM17
Freitag, 9. März 2012, 03:42
I have done alot of reading but all I can find is related to an Aquaero 4.
As the subject suggests I have an Aquaero 5 Pro and a Koolance INS-FM17 (NO FREQUENCY BOARD) just the basic flow meter.
How can i connect this to my AE5 Pro?
I would like to use the flow meter connection to leave my fan connectors free.
Which of the 3 pins do i use as the INS-FM17 only has 2 wires?
Many Thanks
hugostiglitz
Sonntag, 11. März 2012, 11:23
Well I have found the solution.
Use the 2 outside pins on the 3 pin Flow connector. (ground & flow siginal)
I used a calibration value of 197 and it seems to be good.
spiritamokk
Koolance INS-FM17 without adapter with Aquaero 5 PRO
Montag, 30. April 2012, 17:43
Can you please describe how exactly did you plug that sensor to Aquaero 5 PRO, because I tried to plug it using just sensor and pins #1 and #3 (Ground / Flow ) on my Aquaero 5 PRO but i have no data coming =( You said you pluged it without adapter, right?!
Thank you!
chippie
RE: Koolance INS-FM17 without adapter with Aquaero 5 PRO
Freitag, 4. Mai 2012, 03:18
Thank you!
I assume you have connected it to the flow sensor on Aquaero using theouter two pins on the connector. You should be getting a reading if so. However a friend of mine did the same and accidentally touched the center pin with one of the wires and this blew the flow meter, so you have to be very careful when wiring them in. Yes you connect it up without the adapter/converter.
