• 05.10.2026, 09:14
bob452
multiswich scripts and few other questions
Dienstag, 13. März 2012, 11:30
Im new to the "aquacomputer world" and I was looking to use the multiswitch-script-generator-ng I found here:
Multiswitch Script Generator NG - *v1.3*
But I cant make the scripts work with my multiswitch
So here are a couple of question
* is the version 1.3 the last version? Is it compatible with aquasuite 2012 beta?
* What is the pin setting for jumper N°4? I tried closed, but it seems
to just fonction with the button. I tried open, but nothing happens at all
* Does it support PWM function? (something like: power amp N°1 on at 50% , 25% , 75% )
My multiswitch is usb connected and im running windows 7 64
When my multiswich is connected to the aquaero with the aquabus, i can see it in the aquasuite 2012 (MS1 led, MS1 AMP....)
But when the multiswich is connected by usb, i dont see it anywhere
*Shouldn't he appear in the aquasuite?
*How to control the leds and power amp if I dont use scripts and set the pin N°4 open?
*I use Aquasuite 2012 beta for the aquaero but should I use the older Aquasuite for the multiswitch ?
Thank you very much for having read me to the end and sorry for my poor poor english
bob452
Mittwoch, 28. März 2012, 13:27
Well, resolded. Kind of ^^
I installed the old aquasuite 4.72 and i can at last find the usb-multiswich on my computer. Now, i've still a lot to try and test ^^
