• 06.10.2026, 11:00
Grasshopper
11.8v @100%
Sonntag, 8. April 2012, 05:07
Aquaero 5 Pro (run time 28hrs)
water block (AQ5 temps all <30C)
Fan 1 - DDC T1 (#1)
Fan 2 - 3 * fans
Fan 3 - DDC T1 (#2)
Fan 4 - 6 * fans
Only Fan 3 will provide 12volts @ 100%
bcikota
Sonntag, 8. April 2012, 10:03
Hi Grasshopper,
A small voltage drop is normal for this type of voltage regulator, the higher the load the bigger the voltage drop.
11.8V is quite normal.
Kind regards,
Boris.
Grasshopper
Montag, 9. April 2012, 05:14
not sure i am quite as accepting Boris,
a $1 12 volt ( ie 7812 ) voltage regulator has no problems maintaing 12 volts at the DDC 1T work load of ~900mA,
is it wrong to expect a $150 fan controller to offer normal voltage range.
after 4weeks delay due to stock and a further 3 weeks wait for German and Aus post, should I not feel just a little let down.
iBeta2
Mittwoch, 11. April 2012, 00:16
is it wrong to expect a $150 fan controller to offer normal voltage range.....
Have you checked the input voltage to the Aquaero? With the cheap regulators, the output will be no more than Vin-0.7V, so there is no way you can put 12V in and get 12V out.
