• 06.10.2026, 15:45
MaFi0s0
Aquaeros fan turn off
Freitag, 27. April 2012, 08:38
Is it possible for the Aquaeros to turn off a set of fans once CPU or water temp reaches a certain temperature?
Nihil Simile
Freitag, 27. April 2012, 18:30
Yes if you use the curve controller you can set the power @ 0% until it reaches a determined temp and the fan can be graduated up as temp increases. Their are other ways to control as well. I prefer the curve controller.
