• 30.09.2026, 13:47
Rjrolyn
AquaComputer Eheim 1046 Compatibility
Freitag, 27. April 2012, 18:29
Greetings .....
I was curiois about compatibility with the Eheim 1046 pump if it will work with the Aquaero 5xt. I hate to see this go to waste as i have one from the previous Aquaero 4 Thanks in advance
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Rjrolyn« (27. April 2012, 19:05)
Rjrolyn
Dienstag, 1. Mai 2012, 00:21
So no one knows nothing. What a shame
franknitty69
Dienstag, 1. Mai 2012, 19:40
i don't see why this pump would not work. it only draws 0.41a which is within the AQ5/PA2 load spec.
Donnerstag, 10. Mai 2012, 16:21
If you mean the aquastream XT: sure, that can be also used with the aquaero 5 via aquabus.
If you mean an Eheim 1046: that will not work at all with the aquaero. It is a normal 230V pump without any controller etc.
