• 03.10.2026, 02:59
Rjrolyn
Aqua-Twin Connect Parallel Connection Info
Samstag, 12. Mai 2012, 18:51
HI everyone
Ive been searching the net about on how to do parallel connection with the Twin-Connect. Currently i have Tri-Sli GTX 470's w/AquaGrafx. Here's a picture that i have question on and how many of these needs to be inserted in the Twin-Connect (" Highlighted in Blue ") to successfully do a Parallel Connection for the Tri-Sli AquaGrafx
Thanks in adavance
Samstag, 12. Mai 2012, 22:55
For a parallel flow setup you will need none of them. Just imagine how the water will run through the twinConnect and you will get the idea:
The headless screws are necessary if you want to let the water run through the blocks one after another.
Rjrolyn
Sonntag, 13. Mai 2012, 07:25
Thanks Shoggy
