• 17.11.2026, 11:37
AP2
aquaero 5 xt fan question
Montag, 21. Mai 2012, 04:36
hello,
im thinking about adding another ams 240 rad to my system and was curious on how many fans can i run off the aquaero. i would like to configure it like this:
fan channel 1: 2 gentle typhoon ap-15 running at 800 rpm (ams 240 rad)
fan channel 2: 2 gentle typhoon ap-15 running at 800 rpm (ams 240 rad)
fan channel 3: 2 gentle typhoon ap-15 running at 800 rpm (case front intake and rear exhaust)
fan channel 4: 1 scythe 40mm running at 1500 rpm for cooling PA2
fan channel 5 (PA2): used to control d5 pump e
thanks in advance!
Dienstag, 22. Mai 2012, 09:35
Should be no problem. The fan is rated at 1W. The aquaero can handle up to 20W per channel and 60W in total when the voltage regulators have a good cooling. Your setup with th fans will be far away from these limits.
