• 03.10.2026, 21:48
theboyriley
Aquaero 5 LT questions
Samstag, 26. Mai 2012, 13:00
Is it possible to use an aquaero 5 LT with 12 Scythe Gentle Typhoons (1450 RPM)
I would be splitting them to 3 per channel, from what I've read on here this should be ok, I'm guessing I would probably need to strap a heat sink to the aquaero.
Wanted to grab some advice before I go ahead. any suggestions welcome, bit more info; cooling 4 triple radiators, I don't need to control the pumps, there will be no external access to the aquaero (there aren't any 5.25 bays), so USB interface is essential to the system etc.
http://www.overclock.net/t/1185758/project-sr-2-desk
bcikota
Montag, 28. Mai 2012, 09:26
Hi theboyriley,
You should have no problems running that configuration on your LT provided you install a heat sink.
Something like:
http://shop.aquacomputer.de/product_info…roducts_id=2692
Or the waterblock:
http://shop.aquacomputer.de/product_info…roducts_id=2671
Aquasuite 2012 which you need for your Aquaero is still in development, so some things will be inaccessible on your LT (like logging etc.) until they implement it in the future versions, but the main things should work.
Kind regards,
Boris.
