• 02.09.2026, 15:18
jacenty
Aquarero 5 PRO - connection problem.
Montag, 28. Mai 2012, 17:47
I have a problem with connecting Aquarero via USB. When Aquarero is connected via USB, I see "Unknown Device" in Device Manager. Everything is connected according to the istructions of Aquarero and motherboard. Why? Is it possible that the cause is a faulty USB cable?
Thanks for reply and sorry for my english :)
Dienstag, 29. Mai 2012, 10:09
Could be also a problem with Windows, drivers, the mainboard etc.
Maybe you have another PC so you could test it there to see if it makes a difference. This way you can check if the device is faulty or if it is a problem with your PC.
Hybertz
Mittwoch, 30. Mai 2012, 00:44
Do you have any Razer devices connected? If so try and disconnect them all and see if that helps - I had a problem much like it where my aquasuite wouldn't detect my aquaero until both razer keyboard and mouse was disconnected. When I finally got the aquaero and aquasuite talking I updated the firmware of the aquaero and afterwards I could just plug the razer devices back in without any problems.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Hybertz« (30. Mai 2012, 00:53)
jacenty
Samstag, 9. Juni 2012, 18:54
It turned out that Aquarero is broken. On the other computer is also not working. Operating System is clean, without drivers other devices. Well, bad luck :(
Montag, 11. Juni 2012, 12:18
Please send it back for a check/repair.
