• 29.11.2026, 23:28
Psychor
AQ5 Software Sensors - temperature only?
Samstag, 23. Juni 2012, 04:25
I'm currently running AIDA64 v2.50.2018, Aquasuite 2012 Beta 14 and "aquacomputer-service.exe" alpha 2. With "aquacomputer-service.exe" I'm only able to select a total of 4 temperatures from AIDA64. Even though I've set AIDA64 to share all my sensors it seems I'm only able to select temperature sensors. Is this intended?
Thank you.
Samstag, 23. Juni 2012, 11:03
The software sensor function is only available for temperature sensors.
Psychor
Mittwoch, 27. Juni 2012, 22:07
Is this a technical limitation or something that could change down the road? It would be great if we could have our graphs (e.g., fed by AIDA64) all in one place.
Donnerstag, 28. Juni 2012, 11:30
That will not work. It is way to complex to transfer such informations to the aquaero. It would cost a lot of time and money and in the end only a handful of people would it.
Also a graph can easily done in the aquaero by using the external software sensor as a source.
