• 29.09.2026, 02:59
Avathar77
AQ5LT Fan header problem
Freitag, 29. Juni 2012, 08:05
I have an AQ5LT unit that was working fine till today.
My case fans (4 x Arctic F12 fans) were not spinning so I had to see what it was.
I connected 3 of the same fans(F12) to all the headers except the one which says D5 pump(techo signal only) and the RPMs and Amps were very different on one of the headers.
Turns out that one of the fan headers("case fans") is getting lot of current(1.97A)!
All the headers are at 100%.
Uploaded with ImageShack.us
Is it RMA time :(
Freitag, 29. Juni 2012, 09:16
Looks like some part on the controller is damaged and also causes the weird values.It is very unlikely that this just happens alone so maybe there is a problem with the wiring or one of the fans it not OK.
You will not be able to fix that yourself so the device must be send back to your dealer so he can forward it to us or you send it directly to us. Please note that in case of an self-inflicted damage we will charge at least the shipping costs back to you.
