• 14.11.2026, 05:54
Barfastic
AQ5 setup LED STRIP
Donnerstag, 19. Juli 2012, 07:08
Hello all!
I have purchased myself an AQ5 pro, along with 3 PA2 ultras.
What i wanted to ask is, which port should i connect 2 led strips i have to?
Let me also note, i have 2 swiftech 35x pumps that have pwm control.
If i connect the led to the pwm ports, where should i connect my pumps to have control?
Or
If i connect the pumps to the pwm ports, where should i connect the led strips to?
Any advice tips would be great!
Thanks alot :)
Donnerstag, 19. Juli 2012, 15:46
You can use the LED stripes with the two PWM ports. Do not confuse these ports with the PWM speed control signal. These two ports use a pulsed 12V signal and do not work as a PWM controlling signal like you have it on fan channel 4.
For the pumps you could get a 4-pin y-adapter and connect it to the 4th fan channel. This channel offers are PWM controlling signal. The power for the pumps should come directly from the PSU.
