• 09.10.2026, 05:43
nick2002a
Poweradjusts 2 and temperature sensors attached to Aquaero not recognized
Sonntag, 29. Juli 2012, 16:49
Hello,
I have to confess that I am very new to the Aquaero family,
so my questions may seem a little on the dim side.
I have an Aquaero 5 Pro + water block with 3 x Poweradjust 2
USB devices (arrived just this Week) and I am trying to bench test the devices before
assembling inside my PC.
The firmware for the Aquaero is 1022 and it is hardware
5600. I'm not sure what version of the firmware the PowerAdjusts are using, but
given they were on backorder for two months, I'm assuming that these are new
units that were uploaded with the most recent firmware before they left the
factory.
The configuration that I am trying to setup utilizes 20 fans
and two MCP655 pumps.
I have 4 fans connected to fan headers 1, 2, 3, and 4. I
then have 4 fans connected to the first poweradjust and the two pumps with flow
sensors attached to the second and third poweradjust units.
I also have 8 temperature sensors connected to the Aquaero.
So the first question is, whilst cycling through the
different sensors and devices I can only see the temperature reading for
temperature probes 1, 2, 3, and 4. How
do I get to view the temperature for probes 5,6,7 and 8?
The second question is related to the fact I cannot see the poweradjust
units in the Aquaero. When I power everything up the pumps and fans attached to
the poweradjusts startup, but I cannot see them in the Aquaero. I have
connected the Aquabus High to the first PA unit, I then daisy chained the PA
units so that header 2 on the first went to header 1 on the adjacent PA unit
and so on.
The one thing that I thought was a little odd, is that the Aquabus High has
a four pin connector, whilst at the aquabus on the PA units is 3 pin, I assume
that the forth pin on the Aquabus high header is not used in this situation or
I am I missing a special cable?
Please help.
Best regards,
Stuart
Rioga
Sonntag, 29. Juli 2012, 22:01
Hi nick!
There is a step you miss:
You have to connect one by one every power adjust to the pc via USB cable, open aquasuite 2012 Beta 15, update the PA to the 1004 firmware, assign a diferent aquabus channel to every PA (50 for the fist, 51 for the second...).
After that, you can connect the 3 PA to the aquaero via the aquabus in the way you describe. You will see 3 more FANs, 3 temp sensors and 3 flow sensors in aquasuite.
The aquabus only uses 3 cables, no problem with that.
Wish this will help you. :)
regards!
nick2002a
Montag, 30. Juli 2012, 14:15
Thanks for your help. I will give this a shot. Is there a reason that I can not see all 8 temperature sensors on the front of the Aquaero ?
Thanks
Stu
Rioga
Montag, 30. Juli 2012, 16:37
Sorry, i cant help with that, I have the LT version of aquaero.
bcikota
Montag, 30. Juli 2012, 17:52
Hi nick2002a,
Are you saying that you can not see temperatures from sensors 5-8 on your Aquaero LCD?
Did you add additional information pages? You can do so from the Aquasuite 2012 or directly on the Aquaero, under User interface.
Kind regards,
Boris.
nick2002a
Montag, 30. Juli 2012, 18:54
Hi Boris,
Indeed I am referring to the LCD on the Aquaero, I am yet to install the Aquasuite, as have not actually installed windows on the system yet. I'm still in the loop testing and hardware testing phase. I did not know that I had to add the information page for temperature sensors 5,6,7, and 8 . I thought the Aquaero auto detected the sensors and displayed them accordingly. I see I am going to have to have a further play...
Thanks for you help.
Stuart
chippie
Dienstag, 31. Juli 2012, 14:17
@Stuart,
To get the Aquaero to function correctly especially with the PA2's and the temp sensors you will need to configure it via Aquasuite as mentioned above (esp. with assigning different addresses to each PA2) but once done the information is then stored on each device. If you have a usb "A" to usb header cable you could always just connect them up to a laptop and configure them from there if you are not planning on installing an OS soon.
Install the latest software and then connect each piece of equipment in turn to the a USB post. Then update the firmware on each and assign seperate ID's for each PA2 as described by Rioga.
Hope all goes well with the build! :)
nick2002a
Mittwoch, 1. August 2012, 00:19
Hi Chippie,
That is a great idea, I hope to press the big red button this weekend. Both loops look to be in good shape, I just hope my ring main can handle the power :)
Stu
matthelm
Freitag, 3. August 2012, 06:28
OK, where do you "assign" the "Channel"???? (screenshot please?)
matthelm
Freitag, 3. August 2012, 06:59
OK, I was already on Channel 50. No 5th fan on the software when hooked to the AQ5
matthelm
Samstag, 4. August 2012, 17:33
Found my problem. Had the wrong connector on the AQ5.
