• 13.10.2026, 20:16
impac
Aquasuite 2012 + Power sensors
Mittwoch, 22. August 2012, 08:45
Hello,
I was wondering what is the best way to use the Power measurement in the sensor section? It asks for Flow, Temp1 and Temp 2.
I currently am using Flow 1( 4.6L/m) + S1 Ambient temp (31C) and V2: Average loop Temp (37c) and I get a power ratting of 1700W. That seems like an aweful lot considering my Power supply is only a 1200W. Any thoughts? or suggestions on the proper way to measure power?
The above example is under light usage.. the power measurement has gone up to 3700 Watts under benchmarking.
Thanks,
Patrick
Mittwoch, 22. August 2012, 09:59
You have to use 2 sensors:
Radiatior: Air in / Air Out
or
Radiator: water in / water out
you cant mix air and water temperature sensors.
The base of power calculation is this:
http://en.wikipedia.org/wiki/Heat_capacity
