• 30.09.2026, 02:48
DrunkenJim
Software Sensor problems, Windows 8
Dienstag, 13. November 2012, 23:18
Hello all,
i'm having a problem getting the software sensors to work, ever since updating to win 8 i get a blank selection window as below screenshot.
strange thing is it still shows my previous windows 7 selection as already being selected, but it still just sits at the default 50 deg.
I have upgraded to release 1 and firmware 1026, but same result.
thanks in advance for any help,
Jim
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »DrunkenJim« (13. November 2012, 23:22)
Mittwoch, 14. November 2012, 15:00
That is a problem of Open Hardware Monitor. You can try to use the previous version or if you have some programming skills download the source code and compile it because for some strange reasons this will also work correctly.
DrunkenJim
Mittwoch, 14. November 2012, 15:08
Thanks mate, downloaded 0.40 beta, all works now.
