• 22.11.2026, 21:30
mandrix
Limit to number of curve controllers?
Freitag, 16. November 2012, 03:27
I can't set up more than 4 curve controllers. Is this a limit or a bug?
I'm running Aquasuite release 1, I never tried more than 4 on the beta.
Freitag, 16. November 2012, 07:06
jes, the numer of each controller type is limited.
4 - curve controller
8 - setpoint
16 - 2-point
32 - preset
1 - rgb
mandrix
Freitag, 16. November 2012, 11:21
Didn't see that one coming. Is it resource heavy, or some particular reason why there can't be more?
Thanks.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mandrix« (16. November 2012, 11:22)
RAYs3T
Mittwoch, 13. Januar 2021, 23:47
@sebastian Any chance that we can get additional curves on the Aquaero 6 LT when combined with a QUADRO / OCTO?
4 Curves for a total of 12 fans is a little less.
Seeing that this was already an issue ages ago, there might be a possibility to implement this these days?
Donnerstag, 14. Januar 2021, 04:01
If you slave a quadro/octo to an aquaero WITH aquabus, you loose the curve controllers from the quadro/octo, and have only the 4 curve controllers from the aquaero.
If you do NOT slave the quadro/octo to an aquaero, connecting only by USB, you will have 4 controllers from the aquaero AND 4/8 from the quadro/octo for a total of 8/12 curve controllers.
