• 11.10.2026, 20:23
Extreme-Moder
conecting aqualis xt to aquaero 5 pro
Sonntag, 2. Dezember 2012, 23:19
hello
i got a aqualis xt nano and i conected that true usb but i want to change to aquabus cable so i got one but if i conect by aquabus the aquaero does not recognise the aqualis .
whit usb on everything works perfect but the thing is that i only have 1 usb on my board and i need that to the aquaero 5
edit. from aqualis byaquabus to aquaero needs to be on aquabus 1 or aquabus 2 ?
the manuals from aquacomputer dont state this for the aqualis they need to improve tutorials and manuals alot more
can some one help please ??
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Extreme-Moder« (2. Dezember 2012, 23:30)
Montag, 3. Dezember 2012, 10:22
Make sure that you connect it to the highspeed aquabus port on the aquaero.
Extreme-Moder
Montag, 3. Dezember 2012, 11:43
hi
its conected to the hispeed aquabus but if i disconect the usb it desapears the aquasuite !
on aquasuite i chose the option priority aquabus but what is the port number ? at the moment its on 12 .
do i have to do anything elese for this to work ?
Dienstag, 4. Dezember 2012, 08:44
You will not see any special tab for the sensor. It only offers a sensor value. If you click on the white plus icon in the lower right corner of an overview page you can add a new element. In this list you should also be able to see the sensors value from the mps.
